Remote Control Help Please. (1 Viewer)
Jon*W
Hello All,
My theater construction has begun...Yippeee. I have a quick question on controling lights and components from 1 remote. The main obstacle I have is the components will be directly behind me at the back of the room and the dimmer switches will not have line of sight for IR.
Can someone give me some suggestions on products that will allow me to control components and lights with little or no line of sight.
Any suggestions would be appreciated.
David Noll
I have Lutron lighting dimmers installed and I use an iPronto TSi6400 wireless remote to control everything in my theater. No need to point it at equipment.
David
Andrew Pratt
Depending on which remote you use you may find its powerful enough not to need a repeater...though in my experience most do. There's a whole host of options from the very simple IR Repeaters that you can buy at Radio Shack to more elaborate hardwired systems. The hard wired systems are more reliable but are obviously more work to install...and more expensive.
Jon*W
Thanks for the responses.
David,
Is your equipment and Lutron Dimmers in line of sight or around a corner etc?? Just trying to get an idea of how powerful the Remote you suggested is.
David Noll
Jon,
I can take my remote anywhere in the house and it will work my equipment and dimmers. Behind my equipment there is a network extender that receives the signal from the remote, it then sends that signal to the equipment via a wire with a IR sensor that is stuck to the face of the equipment, near the equipment's built-in IR sensor.
David
Patrick.C
You could go with an IR/RF capable remote like the Home Theater Master MX-600. Its emits both IR and RF and comes with an RF base station that you put in your equipment cabinet. The base station receives the RF signal and has IR repeaters that you mount in front of your equipment.
Cameron Wright
Just grab a Xantec 291-10 KIT and run some cat-5 to the dimmer and splice the emitter on the end... off the top of my head thats what I would do...
acinstallation921
