Remote and light control (1 Viewer)
bphillips921
Brad
Adam Gregorich
What to watch tonight?
The Other Washington
Adam
I haven't tried using an IR sender, but in a previous theater room I used a Lutron IR switch and it worked great. Added the wow factor inexpensively. Just skimming I'm not sure that the one you linked to was an IR model. I think you would want something more like this one. Keep in mind there are a couple of different versions depending on the wattage and types of lamps you are dimming.
bphillips921
Brad
The Lutron switch I linked to is controlled via wi-fi, not IR. So the tablet remote would have an app on it to control the lights.
Jeff S in NJ
Northern NJ
Jeff Sumberg
The Lutron Caseta line of dimmers are not WiFi, but it is radio wireless as you say. It uses some proprietary wireless band/protocol called "clear connect". In order to use the tablet/phone apps you also need a internet gateway device for an additional $70 or so to connect from the internet to the switch.
I am considering one of these for my basement theater but the Pico hand remote would be sufficient for adjusting the lights.
Jeff S in NJ
Northern NJ
Jeff Sumberg
I installed a Caseta dimmer in my basement theater over the weekend. I love it and I highly recommend this dimmer. It works perfectly with the LED bulbs from Phillips and Kree that are installed in the ceiling. I bought the kit that came with the dimmer and a PICO remote. That remote is from the "viewing area" so the lights cam be turned on/off. I also bought another PICO remote with a wall mounting plate. This became the on/off switch for the room by the door. The location of the original bat handle switch, where the dimmer is now installed is a tad inconvenient to get at, so the new remote wall plate allows you to "add a new switch" basically anywhere you want without wires. Total cost for everything about $90 at HD (big orange).
acinstallation172
