Gil D
- Mar 15, 1999
While I would expect a $1.5K pre/pro like the Rotel 1066 to be a better design and build than a $1K Denon 380x, I can't really say that I would expect the Rotel to be better in this regard to a flagship like the Denon 5800/5803, Onkyo 989, or HK 8000.
Take a look at the guts of the Denon 5800 for example.
http://www.usa.denon.com/catalog/pdf...0LIT16PAGE.pdf
The hardware looks like alot like what goes into a separates pre/pro. Granted the amp section may not have separate power supplies for each channel, but I don't believe the pre/pro section suffers from it as it's on a separate power supply.
I just don't buy into the fact that a receiver can't be as good as a pre/pro. Why would B&K use the same preamp in the Ref50 as the 507? Rotel I believe may be doing the same thing with their 1066 pre/pro and 1055 receiver. And with more receiver's shutting down ancillary circuits in their Direct mode their is less reason to believe that interference from other circuits is a big problem.
