Rick_B
- Jan 3, 2004
Greetings and Happy New Year!
Question: I'm having trouble with my home stereo receiver and television shutting down when volume is in the medium to elevated levels. Both are connected separately to a surge protector. They are a Kenwood VR6060 and a Panasonic respectively. It seems to happen randomly (i.e. no other triggering event). The higher the volume, the more quickly they shut down (like an internal circuit breaker). The TV comes back on after a few minutes, the receiver needs to be turned off, then back on (a blinking power light indicated that it has shut-down rather than just powered off).
The problem began a couple months after setting the system up. Thus, they operated properly for awhile. Since it happens to both, I suspect there is an outside influence. One shutting down does not necessarily influence the other.
The system is set up with two bookshelf front speakers, two satelights, a center channel and an unpowered sub.
It happens more frequently with the receiver and they have never shut down together (at the same time). The TV had been plugged into the receiver and has since been connected directly to the surge protector but it has made no noticable difference.
Any thoughts and/or questions are welcomed.
THANKS!!!
THANKS!!!
