EdAngell
- Jul 11, 2002
I tried to search, but nothing comes up under "IR"
I would like to know what I need to control my dvd player and receiver which will be in a mechanical closet from an IR "eye" that will be mounted under the screen in my rec-room.
What products can you recommend?
Would something like this work?
Is there a plate that I can put on the wall (like a Leviton quick-connect system type thing) that the IR "eye" can be mounted in?
I appreciate your help, thanks!
