Chris:-/OV
- Sep 7, 2003
Hi guys
I'm planning on building a sonosub but i am limited to certain woofers and won't be able to get Adire Audio subs at all unless there is someone who can bring one or two to South Africa (i will pay all customs, tax etc)
The brands i can get a hold of are all car audio subs so i will have to choose between one of them, they are JBL, Pioneer, Rockford Fosgate, Lightning Audio, Kenwood, Kicker(too expensive here)
The subs i intend on using are 2 Pioneer 12" TS-W305DVC (dual 4 ohm) Carbon Fibre woofers with the following specs:
Nominal Power: 400w rms (max 800w)
Sensitivity: 89dB
FS : 33.9
Qms : 14,2
Qes : 0.379
Qts : 0.370
Vas : 1,79 cu.ft
Xmax : 0.37 inch
I know they don't go as low as subs available in the States but i have been using them for SPL comps and i'm getting 145dB out of them with 600w rms to each so they can take power. (They will probably only get about 110dB in a theater and i realise that).
I just want to know if it could work because the size of the sono tube doesn't matter, i can go as big as is required.
Your help will be greatly appreciated
BTW, very interesting and informative site
Sensitivity: 89dB
FS : 33.9
Qms : 14,2
Qes : 0.379
Qts : 0.370
Vas : 1,79 cu.ft
Xmax : 0.37 inch
