frank<t
- Sep 20, 2003
what do you guys think about the pioneer elite dv-45a pros/cons vs all others
I have one question, concerning the user interface for audio. Do you ever need to go into the menu system to change from 2 channel to multichannel for either SACD or DVD-A?In my experience, you always need to use the players menu to change from MC to 2CH in SACD.
In DVD-A, the Audio button usually works, but IIRC, disc authoring can sometimes screw the pooch on that as well. In DVD-A, you may also be able to choose the group # from the remote, but it is not usually clear what mix is assigned to what group.
If I get a chance, I will try DSOTM, which has MC and 2CH Hi-Rez, plus redbook. I can say with 100% certainty that the menu is needed for the redbook layer, and I am pretty sure that for SACD the menu does allow you to choose MC, 2CH, or CD, and that the audio button does not permit this.
BGL
In DVD-A, you may also be able to choose the group # from the remote, but it is not usually clear what mix is assigned to what group.It's definitely a plus to be able to change groups without the menu system. For the few DVD-A's I have where each mix is in a distinct group, Group 1 has always corresponded to the mch mix and Group 2 to the 2ch mix. IIRC, these discs are the more dated of my collection, so maybe most new ones are supporting the "Audio" means of changing mixes within the same group.
Doug
Having said that, IIRC there is a menu choice that allows the player to switch in and out of progressive mode based on disc content, but I have read that flagging can be iffy, so I just leave that off, and switch with the front panel. Guess I am just a manual control kind of guy.That would be the 'Auto Progressive' function, which I gather (though it's not explicily written) only operates when the 'progressive' light is switched on in front..IOW I'd guess that even if Auto Progressive is set to ON, and the source material is 16:9, it will only output a progressive scan signal if the front button has also been enabled.
That would be the 'Auto Progressive' function, which I gather (though it's not explicily written) only operates when the 'progressive' light is switched on in front..IOW I'd guess that even if Auto Progressive is set to ON, and the source material is 16:9, it will only output a progressive scan signal if the front button has also been enabled.That is what is supposed to happen, but I have read that the 16:9 flagging is also iffy. FWIW, that would be useful for TV's that lock into "Full" mode when receiving a progressive signal.
Since my set does not do that, I have full aspect ratio control at the set and can invoke whatever mode is correct for the software. I thus leave that off.
Side note: I have been in contact with Don Munsil, one of the Secrets authors with various questions about all this stuff. Don is a great guy, and always takes the time to help out. Anyway, I asked if I could simply leave the 45A 3.2 detection in the "on" position when viewing content that is known to be film based, since even films that are properly flagged still have flag issues at chapter breaks and edit points.
The short answer is that it may or may not help. FWIW, the answer he gave was more technical than that, but it exceeded my knowledge of the subject of deinterlacing!
As such, good cadence readers like Faroudja or SI based players will have the advantage on anything but perfectly authored discs, of which there seem to be few.
That said, as they say in the Secrets shoot out, any player will be able to do a good job with properly authored software (my 1600 vs. 45A testing bears that out); its the bad stuff that separates the wheat from the chaff.
BGL
Thanks for the review Brian, any thoughts on audio performance of the 1600?Actually have not tried it save for the digital out to my receiver for movies, which renders any judgement moot. I don't even have a stereo pair hooked up yet, although I will do that eventually.
I am very happy with the 45A for hi-rez and redbook, and since the 1600 only does DVD-A (as far as hi-rez is concerned) PLUS the fact that I have only one 5.1 input means that, assuming the 1600 passes muster for video, thats all I will ever use it for.
BGL
