Sam R. Aucoin
- Jul 5, 1999
Tonight, while watching a movie, my Elite 99 laserdisc stopped working. The tray opens and closes, it accepts commands from the remote by displaying and attempting to do them, but it will not spin the disc. Although I hear what seems to be the laser mechanism moving into position, the disc does not begin to spin and it projects a "U1" code in the upper left corner of the TV.
Before searching for a replacement, does anyone know what could have caused this?
Shortly before this occurred, the disc I was playing (one from the Wyatt Earp expanded edition) began a whirring noise that I have read indicates the disc is not entirely flat. I went up to the player and slightly (and I mean slightly) moved the tray up and down, thinking that might solve the problem (it has, believe it not, in the past). This time, it made my player quit working.
I would really appreciate any input, including suggestions on whether it would be cheaper to purchase a comparable player or send this one off to be repaired. If a send-off is a viable option, where, exactly, does one send a laserdisc player to be repaired?
Sam
Sam
