Pelikan AV Switcher (1 Viewer)
Citizen87645
Cameron Yee
I just bought the Pelikan AV selector that costs around 20.00. I'm using it as a component switcher, figuring that it would work as well as the similar (and slightly more expensive) ones many have purchased from Radio Shack. I have noticed no problems with the quality but wanted to get others' input. Thanks!
Joseph Young
One important note about the Pelican switcher:
When I tried to attach the Gamecube's s-video jack into the switcher, I realized that the input hole is too small (diameter-wise) for the jack to plug in all the way. Pelican's product is nice, and I'm not trying to slam it, but enlarging the area around the s-video input instead of blocking it with those PS2-esque black slats might have been a wise design decision.
Joseph
Citizen87645
Cameron Yee
Yes, I run a DVD player through it. I have a 32" 4:3 non-HD set, so if there is any signal degradation its probably unnoticeable. Truthfully I'm not sure what I would see - would it mostly be color issues or would it also affect aliasing? I mention aliasing because I noticed some watching last night, but I figured aliasing is a result of the DVD compression quality.
Can't comment on the s-video jacks as I'm not using them.
Arthur Legardo
ArthurL
I've come across that problem with my Pelican switcher, had to "scrounge" around for another s-video cable, not good especially when you're anxious to play!
Scott L
I love the little nameplates for the different inputs. I also did A/B comparisons using component through the switcher and then straight to the TV. I didn't notice any difference whatsoever on my 4:3 ntsc wega. Looks good too!
Citizen87645
Cameron Yee
I bought mine at a local Wal-Mart. I have seen them at the local Best Buy as well. I looked at BB online as well as EBWorld but no luck.
Robert Ma
Got mine at Best buy for $17.99. Works great for my S-Video changing. If there is degradation, it must be minimal because I'd be hard pressed to tell.
acinstallation715
