Password protected *folders* in WinME or Win2000?
Discussion in 'Archived Threads 2001-2004' started by Rob FM, Sep 19, 2001.
  1. Rob FM
    Rob FM Second Unit
    Jan 15, 2001
    471
    R
  2. Craig Chatterton
    Craig Chatterton Stunt Coordinator
    Apr 18, 1999
    148
    You can protect the folder so no one other than *you* can access it, but with Windows 2000, that depends on you protecting your password for logging in.
    I think you can also download programs that encrypt directories or files and you'd have to enter a password to unencrypt the file/folder. Check http://www.download.com to find one.
    Virgo: All Virgo's are extremely friendly and intelligent, except for you. Expect a big surprise today, when you wind up with your head impaled upon a stick.
  3. Rob FM
    Rob FM Second Unit
    Jan 15, 2001
    471
    R
  4. MichaelPe
    MichaelPe Screenwriter
    Feb 22, 1999
    1,115
  5. Rob Speicher
    Rob Speicher Supporting Actor
    Nov 24, 2000
    935
    If you have a drive formatted in NTFS, you can set securities on that drive/folder/file by going to the properties for that item, and clicking the security tab. From there, remove 'Everyone' access to the folder and add only your account to that folder.
    Again, this will only work if the drive is formatted with NTFS.
  6. Iain Lambert
    Iain Lambert Screenwriter
    Jun 7, 1999
    1,345
    As a slightly kludgy workaround, if its just a few files you need to protect, you could turn it into a 'compressed folder' which is just a zip file, and password protect the zip, I suppose. I've not tried this yet, and my ME box is at home, so you'll have to test it yourself.
  7. Roy C.
    Roy C. Second Unit
    Jul 20, 1999
    356
    The WinZip thing would work regardless of OS but I would also recommend doing it the way Rob recommended, not only because it's better and easier to use, but because NTFS is a better format and it uses drive space more efficiently (smaller sectors=more usable space). You can also set the drive to be compressed which gives you even more space to work with.
    Roy C.
  8. Rob FM
    Rob FM Second Unit
    Jan 15, 2001
    471
    R
