Palm Pilot trouble
Discussion in 'Archived Threads 2001-2004' started by Jeremy Illingworth, Oct 6, 2001.
  1. Jeremy Illingworth
    Jeremy Illingworth Supporting Actor
    Nov 12, 2000
    535
    My woman bought a Visor (PP clone) last winter and now she's having a problem with it. When she pulls up the keyboard (on screen) to type with the pen about two thirds of the time the letter next to the one typed in is used. She's finding the warranty card and plans to take it back. Is this common for PDAs or this brand? I was also thinking about getting one but don't want this to happen to me.
    jeremy
  2. Brent Cantrell
    Brent Cantrell Stunt Coordinator
    May 7, 2001
    244
  3. Jeremy Illingworth
    Nov 12, 2000
    535
    Is the realignment procedure in the manual? Should it be done on a regular basis?
    jeremy
  4. David Lambert
    David Lambert Executive Producer
    Aug 3, 2001
    11,380
    38
    I wouldn't mess around with it. I'd call HandSpring and get them to perform whatever warranty service they currently provide. Find the warranty card - if even necessary; it may not be if you have the receipt or another record of the transaction (like a credit card statement) - and call them up pronto.
    Most times a place like that will help you over the phone. If not, they will have you send the unit in for repair. I don't know what service HandSpring is providing right now. Maybe they'll just switch it out for another entire unit, maybe they'll fix the one you send in and get it back to you. If they're really good, they'll take the data off before the repair/replacement and restore it afterward.
    See what they do. Let us know what they say; it might be useful info in the future. Good luck,
    DAVE/Memphis
    [​IMG]
    MORE TV ON DVD, PLEASE!
  5. Brent Cantrell
    May 7, 2001
    244
    Realignment is where you tap the center of the cross with the stylus. It's supposed to be done every couple of weeks, and is intended to be done by the end user. Unfortunately, since I've made the switch to an Ipaq (3630 upgraded to 64MB ram) I don't remember where that option is.
    Look online, it's easy and can help.
    http://www.dvdprofiler.com/mycollect...lias=BCantrell
  6. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    I don't know how close the Visor version of PALM OS is to the Palm OS itself but...
    You have to run DIGITIZER to align the screen every couple weeks. Don't return the thing for warranty service- this is a common issue, not a big deal. It would be like you taking in your DVD player for warranty repair in order to change it to 16x9 mode!
    Go to the home screen (press home on lower left) and make sure the category in the upper right corner is ALL (or SYSTEM). In the list of Icons you should see on that says PREFS.
    Tap PREFS, in the upper right you'll see an arrow with GENERAL next to it. Tap general and it will pull down to various pref categories. The second one down should be DIGITIZER. Click that, and follow the directions.
    This should recalibrate the tap locations.
    On a side note, the entire point of having a Palm is that it easily recognizes handwriting. I would recommend to your ladyfriend that she bypass the keyboard entirely. Will a little practice I can get way faster response from writing- and I can do it without even looking at the plam at all. The keyboard is a pain, even with a calibrated screen, handwriting is the way to go.
    -Vince
    http://www.musicianassist.com
    AIM: VinceMaskeeper
    Interested in moving into FRONT PROJECTION with huge 6-10 foot widescreen? Buy my whole HDTV-ready CRT based front projection system delivered, cheap! Click here
    [Edited last by Vince Maskeeper on October 07, 2001 at 09:36 AM]
  7. Mark Dubbelboer
    Mark Dubbelboer Screenwriter
    Oct 6, 1999
    1,008
    I've got a Visor. just follow the instructions that vince gave.
    There is nothing wrong with her visor it just needs re-alignment
  8. Brent Cantrell
    May 7, 2001
    244
  9. Jeff Blair
    Jeff Blair Second Unit
    Apr 30, 2000
    335
    Brent is right. the OS is the same. And a little trivia fact for ya. The makers of the Visor are the same Guys that made the Palm Pilot. They started there own company. I do like the visor better, because of the "module" slot. I am about to get a little memory card for it.
    Jeff Blair
    AIM blairj2
    Most folks are about as happy as they make up their minds to be.
    - Abraham Lincoln
    My DVD's
  10. Jeremy Illingworth
    Nov 12, 2000
    535
    Problem solved, thanks for the help.
    jeremy
