Ok, what kind of setup do I need for a HTPC and a HDTV?
Discussion in 'Archived Threads 2001-2004' started by Micheal, Sep 18, 2001.
  1. Micheal
    Micheal Screenwriter
    Apr 13, 1999
    1,523
    I have a Toshiba 40x81 HDTV and I'm looking into getting a HTPC that can do progressive scan. I'm also looking to add a FPTV in the next year or so..
    I don't want to spend a fortune on the HTPC but I don't want it stuttering through the movie.. What would you suggest?
    Thanks for any advice that you can give me.
    BLAM!
    Good, bad...I'm the guy with the gun.
    Check out my movie mural here... http://www.geocities.com/superfacehu...ater_Page.html
  2. Abdul Jalib
    Abdul Jalib Stunt Coordinator
    Dec 27, 2000
    175
    A Celeron or Duron 750 or better has plenty of horsepower. Beware VIA chipsets. Make sure you go with a Radeon LE and ATI Player (comes free with it.) Get a huge high quality power supply if you are going to be using a video capture card for dScaler. Get an old slow DVD player, if noise is a concern.
    http://groups.yahoo.com/group/Philips_HDTV/joinClick to subscribe to Philips_HDTV discussion group
