Jeff Levesque
- May 10, 2001
Skeptic that I am, I waited a long time to decide on a Progressive Scan DVD player to upgrade my Sony S530D player. I bounced between the Denon 2800, Pioneer DV-37, etc. and settled on the Panasonic RP91 due to the enthusiastic response to it on the forums. Excellent piece of gear.
My question is, now what? Are there any tweaks or hidden settings I should know about? I have already been through the initial setup outlined in the manual. When I first hooked it up to my Toshiba 61" HDTV, I was suprised to find the hue setting on full green tint by default. The color looked really bad until I backed it off to 0. After re-calibrating the TV with the Avia disc, the color looks pretty good. The clarity is excellent. No lines at all. What should I do from here? I am happy with the picture, but want to make sure I'm getting the most out of the player. Any input on this is appreciated.
Also, the blue progressive scan indicator turns completely off after about 10 seconds or so. If I use the remote to advance a track, it comes back on for about 5 seconds. Is this normal?
