Oh boy a new subwoofer thread! (1 Viewer)
Chris Popovich
Hello all,
I love my current sub, which is
5.5 cu ft.
Tumult
2 18" PR's
Crown K1
Paradigm X-30
(soon) Feedback Destroyer
(sometimes for fun) Phase Coupled Activator
But then I started getting the itch for design. My current sub is still naked (MDF) but here is what I'm thinking.
I want to make a small sub. Tiny. Super small. For no apparent reason other than I want to. I'm thinking something along the lines of 10" cubed. maybe a little bigger. 4 8" woofs. Sealed (undoutably with Linkwitz transform), or 2 8" PR's. (Does anyone make a 8" PR worth using?)
It doesn't have to go that low 28-30Hz or a touch under is fine. (My Tumult is tuned to about 15Hz). It doesn't have to play that loud either -but a healthy XMax would of course be beneficial. It'd be nice if it wasn't a distortion box.
Any decent 8" out there for a reasonable price?
I'm not worried about amp power -assume I'll have a crown K1 available for playing.
Chris
Rory Buszka
Well, the Tang Band 8" from Nuera should have plenty of excursion and power handling for a Linkwitz Transform. Go with 4 of them. One on each side. Then put the binding posts on the back and connect up to an outboard amplifier for plenty of power. That's just a small sealed box with 4 woofers. Something different will be necessary for PRs.
Mark gas
You might wanna try the New ED big 8's comming out. One or 2 should work good with the power you have in a ported box.
blitz
