TedD
- Jan 9, 2001
A Heads-Up for anyone considering purchasing NVDVD:
I have been trying to license this software for the last 4 days in order to check the quality of the filters compared to Sonic Cineplayer.
NVIDIA and their partner Globalware were anxious to take my money and promptly charged my credit card when I performed the online activation.
Only, the unlock didn't work, and it has taken 72 hours to get them to email me an unlock code to use.
The next problem is that the unlock code that was sent via email didn't work either. After entering the unlock code and rebooting, I was presented with: ta-da! a screen to fill in my credit card info to purchase the product!
At this point I have to recommend that you ALL stay away from this product until the issues with the activation system are corrected, or the activation system is removed.
Aparently, this activation system hides files all over your HD with bogus names like 5dfjovma.sys and other files that look like dll's but are part of the copy protection scheme and contain text rather than code.
Even if the unlock had worked, since I use my E: drive for a development partition and my C: for production the placement of the 5dfjovma.sys (marked as a system and a hidden file BTW) on C: means that if I should need to restore a ghost image of my C: drive, it will break the licensing of a program installed on E:.
This is not an acceptable solution. I have requested either a version of NVDVD that will work on my system or a refund of the $39.95 credit card transaction.
Other Issues:
If you start the trial period, then remove NVDVD before the expiration of the trial, you will not be able to reinstall it.
Slow response time of the NVIDIA support site.
Ted
Other Issues:
Ted
