Brian Fineberg
- Sep 1, 2000
I have a question on what should be my next upgrade? A svs to replace my sony sawm40, or matching surrounds for my Klipsch Rf-3's, Rc-3..?? What do you think will be more important? Also if it is SVS would a 100watt SOny shelf sytem be ok to power it?? And could I just hook it into the vcr in??
I am leaning toward the SVS but I was wondering your opinions on what is better upgrade. The RS-3's are around the same price as the SVS 25-31cs. Thank you for your input(in advance)
-B
p.s. I already have surrounds just not matching ones and this is all run by a denon 3801. Thanks again!!
-B
