Ricky Hartanto
- Mar 27, 2002
Hi,
I went around Madison in search for TV and could not decide on which TV I should purchase. I have seen Sony Wega, Pasonic, Toshiba, and Sharp. They are all in almost the same price range that I can afford (budget constraint).
I noticed that the sharp produces white color "more white" while the panasonic produces it "more creme". A best buy support person said that the Sony may be the best TV that they have to view DVDs. The reason is that the Sony has the 16:9 compression features that makes it not to loose resolution when viewing in "panoramic format".
Would you please help me decide on which TV that I should buy or which brand that I should avoid if there is any.
I will get the TV locally as delivery costs would just increase the purchase cost.
Thank you so much for your help.
Sincerely,
Ricky
Sincerely,
Ricky
