New HDTV - PC DVI to HDMI input?
Discussion in 'Computers' started by Stephen Orr, Feb 12, 2006.
  1. Stephen Orr
    Stephen Orr Screenwriter
    Mar 14, 1999
    1,099
    My wife bought me a new Sony HDTV-ready set for Christmas. Now I am getting ready to move a 2.4 GHZ Dell computer downstairs to act as a media center. What can I expect if I run my DVI output from the PC to the TV's HDMI input? Should I be able to surf the net using my new TV, and run my Beyond-TV recorded programs?
    Thanks in advance.
  2. Parker Clack
    Jun 30, 1997
    12,214
    58
    Kansas City, MO
    Parker
    Stephen:
    You will be seeing your laptop on your RPTV. So whatever you have up on it whether is is your webbrowser, Beyond-TV, etc. you will see on your Sony. Over this connection you will also be able to upconvert your DVDs, etc. to the highest res of your monitor too. Since DVD is normally at 480p and Macrovision limits it to 480p over component you do not have this limitation over HDMI.
    So the bottom line is that your laptop will look great over your Sony and will only be limited to the limits of your video card in your laptop.
  3. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    www.monoprice.com sells cheap (~$5) DVI->HDMI adapters and DVI->HDMI cables. Just an FYI.
    You may have issues with 1:1 pixel mapping...your mileage may vary. You may need to create a custom resolution on the PC if your Sony display has an oddball resolution like 1366x768. Again, YMMV.
  4. Chris Bardon
    Chris Bardon Cinematographer
    Jul 4, 2000
    2,059
    I've had a PC hooked up to my Sony with DVI->HDMI a couple of times, and the results are pretty damn good. You'll probably have to play with resolutions a bit to find the "optimal" one, but if you have an ATI video card, there's a decent HDTV resolution selector in the catalyst control panel.
