Rob Varto
- Mar 5, 2000
I know this topic has been discussed ad nauseum... I still need come clarification though. I have a BB connection to my PC upstairs and I want to establish a wireless connection to my PS2, XBox, and my HTPC which are all downstairs in my living room.
I know I will need a wireless router (BEFW11S4)... but then the confusion sets in. In order to connect to my PC, do I need a wireless NIC or will my current NIC work just fine?
In order to connect to my peripherals downstairs, can I use a WET 11 for all three components (PS2, Xbox, HTPC) or do I need a WET 11 for each component?
Or... can I use (1) Wet 11 and use it to connect to a HUB which will then connect to the other two components?
Can anyone clarify this for me? Thanks a ton!
