Netflix Return DVDs
Discussion in 'After Hours Lounge (Off Topic)' started by Chris Huber, May 13, 2005.
  1. Chris Huber
    Chris Huber Second Unit
    Jan 2, 2003
    416
    I took 2 dvds out at a time. I noticed the envolopes have 2 different bar code stickers. Does it matter which envolope they get sent back in?
  2. Cameron Yee
    Cameron Yee Executive Producer
    May 9, 2002
    11,582
    587
    Since 2006
    Cameron Yee
    Nope. Sometimes I just take all the discs out and grab a mailer when it's time to go back.
  3. Scott L
    Scott L Producer
    Feb 29, 2000
    4,466
    I usually stuff two discs in one envelope. I wonder if they recommend it to cut costs? hmmm
  4. Kevin M
    Kevin M Producer
    Feb 23, 2000
    5,172
    2
    Regarding using one envelope for two discs, their site states that if you loose an envelope then just stuff two in one.....I have to say though, since netflix is paying for the postage I can't understand the need to do so other than if one is lost, is it that hard to place two envelopes in a mail box?[​IMG]
  5. Scott L
    Scott L Producer
    Feb 29, 2000
    4,466
    Well if everyone used 1 envelope for two discs wouldn't that cut their postage costs in half?
  6. BrianB
    BrianB Producer
    Apr 29, 2000
    5,211
    Only if everyone is returning two discs at a time, which I doubt is the case.
  7. David Williams
    David Williams Cinematographer
    Mar 6, 2001
    2,290
    Not necessarily. All postage is based on weight, so as long as 2 DVDs in the envelope doesn't push the postage higher than what it costs to mail 1 DVD then it would cost them half as much.
