gene c
I'm sure your 708 and Panasonic BDT110, when connected with an hdmi cable, will give you TrueHD and Master Audio and HD video.. Video isn't my strong point but if you use an hdmi to DVI cable from the 708 to the Sony HDTV then you should get HD video on your older display as well. You may have to change the output resolution of the BR player and satillite receiver to match that of the display which is probably 720P/1080i. Audio jacks aren't necessary if you don't want to use the tv's speakers.
