Need TV advice
Discussion in 'Displays' started by Reid K, Jul 14, 2003.
  1. Reid K
    Reid K Stunt Coordinator
    Jan 16, 2003
    207
    Okay right now iam working on getting the best setup for my 3 next generation consoles so of course one of the logical steps would be an HDTV (mainly for xbox i guess). So with that said most of the use on the TV will be for gaming with some movie watching (wont watch any normal TV on it) Iam looking to spend at most 3000 canadian but would prefer to spend more around 2000 or even less. So can someone recomened me a nice HDTV? My concerns are this:
    1) cost efficent
    2) wont burn in from gaming
    3) nice quality
  2. Agustin
    Agustin Agent
    Jul 3, 2003
    41
    Any HDTV CRT, RPTV or FPTV can be burn,
    you must have an AVIA calibrating disc, so you can adjust settings properly, then plug your consoles, and play,
    I have the same needs and yesterday buy
    Samsun RPTV 42" Widescreen HD for just $1499 dollars, its a cool price for the set and the xbox can handle HD and Widescreen very well.
  3. Reid K
    Jan 16, 2003
    207
    Okay I have been looking into some samsungs (thinking around 32 inches) I found one on best buy for 999.99 but forgot the name....
  4. Reid K
    Jan 16, 2003
    207
    also is there anything I should look for any advice would really be great
