Need to Replace Denon AVR-391 (1 Viewer)
Here is my current set-up on my Home Theatre:
2 Episode ES-500-Point-6 Ceiling Speakers,
3 Episode ES-700-IWLCR-5 In-Wall Dual woofer Speakers,
Episode ES-Sub-12-300 Subwoofer
Must be 3D Passthrough. Any suggestions?
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
You are replacing the 391...Because it died?You want an AVR that does ______ that the 391 does not?Every AVR made the last 5 years passes 3D.
schan1269
HTF Expert
Sam
Herschel Frierson said:
I am looking to buy a new receiver to push the ability of my speakers.
Every receiver, even a $99 Sherwood, "pushes the ability of your speakers".You realize the "80 watts"(guessing, haven't looked up the specs of anything) of your 391 needs you to buy an AVR with 160 watts...to notice any appreciable increase in volume.
schan1269
HTF Expert
Sam
Just looked at the 500 p6. Episode "comparo" is the Klipsch CDT 3650. Bad choice on Episode's part. That Klipsch is 93db efficient.That means you need 4 times the power to run your Episode.
schan1269
HTF Expert
Sam
Saying they are less efficient than other options. There are SPL calculators out there to figure out how much power you need to attain desired volume.
acinstallation482
