Need MAJOR help with the Malata DVD-N996!
Discussion in 'Archived Threads 2001-2004' started by Patrick G, Sep 18, 2001.
  1. Patrick G
    Patrick G Second Unit
    Feb 3, 2000
    Ok, I've got just about everything figured out except this:
    How do I bypass all of the Malata's video (color) settings??
    After pressing the "Feature" key on the Malata remote, one of the options is "Color", for which you can adjust brightness, gamma, saturation, etc. My question is, if I do NOT want the dvd player to affect the picture in any way, should all of these be set to 0 (zero), or should a couple have higher settings (like saturation and gamma)?
    [Edited last by Patrick G on September 19, 2001 at 07:43 PM]
