Huzefa
- May 23, 2002
I bought a Dishnet hd6000 receiver from someone in the hardware for saleforum. I plugged it in and it won't turn on properly (the power light comes on, it says acquiring sat signal, then turns off, and power light blinks ~10 times before going off completely). Dishnet tells me the software is too old on the receiver due to it having been out of the stream for a while. They can't fix it but they want $85 to replace it. Is there something else I can do? Are there any dealers in the Chicagoland area that can fix something like this? Thanks much
Huzefa
Huzefa
