WarrenCo
- May 22, 2002
I can really use some advice on this. I currently use the Morrison ELAD Pre and it sounds really great with the Pass Labs X350 and Aerial Acoustic 10T's but the system is in my bedroom and I really want a remote control for the volume as well as a sleep timer. A tuner would be nice as well.
So my needs are.
1. Great Sound (not bright)
2. 2 channel (more is ok just not a "need")
3. Remote control for volume
4. Sleep Timer
5. 12 Volt trigger (to trigger amp on and off)
6. Tuner
7. Not too expensive maybe $2,000 or less (used is an option)
Any ideas?
Thanx in advance.
So my needs are.
4. Sleep Timer
6. Tuner
Any ideas?
Thanx in advance.
