Need help determining Wattage on Monsoon Computer Speaker System... (1 Viewer)
Brian Harnish
My owner's manual does not list the wattage on the speakers I just bought (and the box doesn't either). The speaker system I got is the Monsoon MM-702 Flat Panel Audio System. In spite of not knowing the wattage, I am literally ENTHRALLED with how my MP3s sound. I'm hearing a whole midrange of sound, as well as bass and higher ranges (where applicable). They blow my older, cheaper speaker system out of the water!
Anyways, the only specs listed in the manual are these:
Satellites: 4x8" diple-radiating PFT Transducer
Satellite Enclosure: None
Total Amplifier Power: 49 Wmax^2, 35Wrms
Crossover: Active, third order at 225Hz
Subwoofer drive unit: 5.25 inch cone driver, Xmax = +_(should be + and - over eachother) 5mm
Subwoofer cabinet: 6.75 liter bandpass, tuned to 110 Hz; 9.50" H x 7.25" W x 10.88" D
Controls on Subwoofer: Bass volume and power on/off
System frequency response: 50 Hz to 20 kHz (in workstation environment)
Maximum SPL at 0.5 meters: 101 dB using EIA 426B noise
...if these will be of any help determining the wattage. Please let me know. :)
- Brian
My DVD Collection
Want Sliders on DVD? Then please SIGN the petition!
todbnla
Todd
Sorry, those are the only specs shown on the website too. Looks like you may have to call them?
The real company name, which you may know is "SONIGISTIX" and a search thru Yahoo will give you their URL.
FYI
Todd
My HT
acinstallation715
