Jeff Jacobson
- Dec 24, 2001
The Front panel audio connector on my motherboard has these pins:
AGND, +5VA, BLINE_OUT_R, (no pin), BLINE_OUT_L
MIC2, MICPWR, Line out_R, NC, Line out_L
The case has these cables for the front panel audio connector:
MIC-IN (Front Microphone input Signal), GND (Front Audio Ground), L-OUT (Front Left Channel Audio Signal), R-OUT (Front Right Channel Audio Signal).
Which cable connects to which pin, and why don't the number of pins match the number of cables? (I'm also having a similar problem with the front panel firewire port.)
Here are links to the manufacturers' websites where you can get some documentation.
Motherboard: Asus A7N8X-E Deluxe
Case: Enermax CS-EN517
