Mark To
- Feb 23, 2004
When I heard about Rhino releasing the complete My Favorite Martian 1st Season I contacted them immediately. The DVD they put out of 4 episodes a few years ago contained a time-sped 22 minute version of the pilot. The other episodes seemed to be fine, running 25:30 each. Here is my letter to them and their response:
I understand you are going to be releasing the complete first season on
DVD. When the show was put out by you in season discs, the pilot episode
was timesped to 22 minutes on the DVD. I complained about this and was told
that nothing would be done to rectify the matter. Will this be corrected
for the season set? Are the people working on this project aware of this
mistake? Real simple, if the show runs 25:30 its the right version. If its
22 minutes, its the wrong version. Not hard to determine. I don't mean to
be flippant but the response I got was basically one of not caring so I am
hoping that a little more pride and professionalism will go into this release.
Thanks for your email. Our video department is aware of the issue, and there are no current plans to amend this episode, but thanks for your input. I'll forward your letter to our suggestion box.
Really shows you how little pride and care goes into these things. This is a simple thing which would just entail them going back to the distributor and asking for the correct speed tape. Obviously since all of the other episodes are the proper speed and running time they were all put on tape this way. But they must feel that 99% of the people either won't know the difference of won't give a shit so why should they bother doing any extra work to put it out right.
