Sean Patrick
- Apr 22, 1999
i want to take this chance to rehaul my speaker wire connections and audio connections overall since i'm moving. Right now i'm using pretty much all el-cheapo digital coax/optical wires for audio and some inexpensive speaker wires. None of it's Monster since I figured the cheap stuff would probably be better (most of the connections come from generic radio shack brand, i think).
Anyway, without spending too much money I'd like to get some input on what quality speaker wire I can get without breaking the bank. Same goes for optical and coax, although I think what I'm using now will do me just fine unless there's some new magical wire out there I haven't heard about. Also, since i will still be using some rca cables (for tape deck/phono preamp/cd record monitor), is it worth upgrading those?
i'd also like to go with speaker wire i can find relatively easy (don't want to special order hand made wire that will take 4 weeks to get).
btw, i have a Harmon Kardon AVR75 Dolby Digital receiver (no dts).
thanks!
thanks!
