Charlie D. M. A
- Sep 15, 2003
Ack.. my speaker wires are short by about 2 feet. The ends are hardwired into the speakers in one end and are soldered at the other. The tips are hard in that it can't be bent, so i can't just twist on extension wires without it sliding off.
What should I do? Just use super glue/duct tape? What should I look for in an _2 feet_ extension speaker wire? The shortest i've seen is 12 feet at $30... seems expensive. :frowning:
These are computer speakers btw, and only need to handle 40 watts per channel
