kurt_fire
- Dec 29, 2002
I would prefer some non-tower speakers, something that won't take up a huge amount of space. Some large bookshelf speakers are perfectly fine though.
Here's some basic questions that I answered! I just want to get the best products I can that are within my budget!
1) What is your budget? - $1000 or under
2) What does your budget need to cover? It needs to cover:
b) receiver - Yes
c) pre-amp/processor - if needed (hopefully not though)
d) amplifier(s) - if needed (hopefully not though)
e) speakers - 5.1? 7.1? how many? - 5.1 or 6.1, really doesn't matter between those 2; including the sub of course tongue
h) cables and wires - don't know for sure, but don't really include these in with the price.
l) furniture of any kind? - needs some front and rear speaker stands if needed.
3) What other equipment do you have already? - DVD player, TV, satellite receiver, VCR
4) What is the size and what are the dimensions of the room? (length x width x height) - pretty big, I'd say 25x25x9. It's going in a big, open style living room.
5) Is this a dedicated room just for the home theater, or is it serving double duty as a family room or bedroom or what-have-you as well? - It's the living room, primarly used for TV use.
7) How is the seating arranged within the room and can it be changed for optimal placement or is it set? - We can adjust this. He has typical couch and chair furniture. Nothing worth noting.
10) How will this system be used: DVDs, regular sattelite TV, some music probably
11) What kind of sound are you looking for? - hard to tell. Whatever will sound excellent when playing a DVD is really all that matters grin
b) receiver - Yes
