Liquid cooling? (1 Viewer)
Jeff R.
Anybody know of any good liquid cooling solutions for a computer. I want to build a system but the noise from all the necessary fans required to keep it cool would probably drive me crazy. I haven't heard of any liquid cooling solutions that work well. Any suggestions?
Glenn Overholt
Jeff, I've always dreamed of liquid cooling too. I am sure that it is possible and the inventor would make a fortune, but good luck.
As for the fans, what you have are noisy ones. I have about a dozen in mine and they are all pretty quiet. If I remember correctly, most PC fans put out about 40+ db. The quiet ones run around 30 db, and that is what to search for. They are usually more expensive, but well worth it.
Glenn
Jeff R.
I saw that same review of the Koolance system. Perhaps this would be more complicated than I thought.
acinstallation715
