Linksys Etherfast Cable/DSL Router Problems
Discussion in 'Archived Threads 2001-2004' started by Rob Speicher, Oct 11, 2001.
  1. Rob Speicher
    Rob Speicher Supporting Actor
    Nov 24, 2000
    935
    I recently got a BEFSR81 to share a cable connection, and at one point it worked. Then I unplugged it for a while, and now suddenly it won't work. Computers connected to it can't ping or browse to 192.168.1.1 - or even to eachother. They can't lease IPs from the DHCP server. In fact, they can't do much as far as networked PCs go.
    I've reset the router several times to no avail. I'm sure it's not the computers themselves, as they go through a regular hub just fine.
    Anyone have any ideas?
  2. SamRoza
    SamRoza Stunt Coordinator
    Apr 27, 2000
    186
    I've had this problem before, and it's all a defualt issue. Sometimes they get kinda flakey and need to be powered down, or to have the reset button held in until it goes into default mode.
    Is 192.168.1.x the default numbering scheme?(I use a different scheme) If not, look at the manual for the defualt numbering and try that. Is the unit returnable? If so, I urge you to try that befire trying to work with Linksys's support system-it sucks.
    Sam
  3. SteveA
    SteveA Supporting Actor
    May 25, 2000
    700
    The Linksys cable/DSL router is a piece of shit, to put it bluntly. I bought one back in May that worked for a couple of weeks - then died. After exchanging the damn thing for ANOTHER non-working Linksys router, I finally switched to the NetGear router. It has worked like a champ for the last four months! The NetGear router also has better documentation and support and is just a better product all the way around.
  4. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    My f&*$king Linkysys BEFSR-11 router just died a few minutes ago! [​IMG]
    ...minutes later...
    Well, it's up and running again, but what a pain in the butt...I might still opt for a Netgear tomorrow!
    [Edited last by Arthur Legardo on October 12, 2001 at 06:28 PM]
  5. AndyVX
    AndyVX Supporting Actor
    Aug 2, 2000
    804
    I was looking into getting the Linksys to connect 3 PC's in my house, plus run one cable to my game systems that will sure to be online playable soon (PS2, Gamecube, Xbox) and switch cables between them depending on which one I'm playing.
    But, after reading this thread, and others on the net taling about various problems with the Linksys, this Netgear one has me interested.
    Can someone post a link to it, or just let me know what the model number is? Does it function the same as the Linksys, giving me a 10/100 switched network, as well as sharing my cable internet access? Thanks.
    Andrew
    ICQ# - 119869807
  6. Arthur Legardo
    Jul 21, 1999
    441
    AndyVX, I went to Practically Networked and read several reviews of hardware routers. I noticed that chose the SMC Barricade 7004ABR router as one of their "High Recommended" routers so I went out and looked for one today. Luckily I found out that Futureshop sold SMC products and was able to pick up one of these routers for $139. You may want to look up one of these since not only does it have a great price, but it includes a 4 10/100 switched ports that auto-sense the type of connection/cable meaning that you don't have to worry about using a crossover cable AND it includes a print server!
    Great value IMHO.
  7. Rob Speicher
    Nov 24, 2000
    935
    I think I'll be returning the Linksys. Does this Netgear look alright?
  8. Shayne Lebrun
    Shayne Lebrun Screenwriter
    Jun 17, 1999
    1,086
    I've been runing a 4 port Linksys for a year now, and the only problems I had were a) my cable modem's fault and b) a VPN issue that was fixed through a firmware upgrade.
    Upgrade firmware.
    Upgrade firmware.
    Upgrade firmware.
  9. Rob Speicher
    Nov 24, 2000
    935
    I would upgrade the firmware, but it won't respond to a ping, nor will the admin system load (pretty much the same problem).
    This is after what I'm sure amounts to several hundred resets and every possible combination of cables, IP addresses and PCs I could think of. I've officially given up.
  10. Shayne Lebrun
    Jun 17, 1999
    1,086
    The only time mine becomes totally unresponsive is when it's trying to grab a DHCP address, and can't.
