Lexicon MC 1 for sale
Discussion in 'Archived Threads 2001-2004' started by Peter Staddon, Nov 9, 2001.
  1. Peter Staddon
    Peter Staddon Stunt Coordinator
    Mar 16, 2000
    88
    Time to sell my Lexicon MC 1. Less than one year old, in perfect condition, sounding superb.
    I've included two links to on line reviews of the unit that are too long to post as well as a listing of tech specs.
    Going to the first offer of $4250 - hell I might event throw in some Fox DVD's as well!!!
    Contact me via Private Message if you are interested.
    Peter
    http://www.sunshinestereo.com/leximc1rev.htm
    http://www.hifisa.co.za/POST/reviews/lexiconM1.htm
    Processor 24 effects for film and music including Dolby Digital, DTS, Logic 7.1, THX Surround EX
    (THX Ultra certified) THD Less than 0.005%
    Audio Inputs 8 stereo (RCA) pairs Dynamic Range 106dB, minimum
    Video Inputs 8 composite (RCA), 8 S-video Signal to Noise Ratio 106dB, minimum
    Digital Inputs 8: 5 RCA, 3 optical Toslink conforms to S/PDIF Input Level 2V rms max
    200mV for Dolby
    RS232 D9 type connector Input Impedance 100kohm/150pF
    Infrared Input mini-phone type direct in parallel with front panel receiver Output level 6V rms
    Audio Outputs 8: left, right, centre, L&R sides, L&R rears, subwoofer Output Impedance 100ohm/150pF
    Digital Output Coaxial conforms to S/PDIF (direct out) Video Compatibility NTSC M, PAL, SECAM
    Video Outputs 3 composite (RCA), 1 Monitor, 2 record
    3 S-video, 1 Monitor, 2 record Video Frequency Response 10Hz - 10MHz
    A/D Conversion Enhanced Dual-Bit Delta Sigma 24 bit Video Signal to Noise Ratio > 70dB ±0.1%
    D/A Conversion Multi-Bit Delta Sigma 24 bit Weight 4.9kg
    Frequency Response 10Hz - 20kHz, ±0.3dB Dimensions hwd 92x440x292mm
    THX Crossovers Dual precision digital crossovers for all channels (40, 80, 120Hz) Finish Black
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Hey Peter,
    Sad to see that you're getting rid of the Lex (especially since you never invited me over to let me play with it!).
    Just curious- are you planning an upgrade beyond the Lexicon, or did the high end HT fever finally pass for you?
    -Vince
    http://www.musicianassist.com
    AIM: VinceMaskeeper
    Do you want SOUTH PARK on DVD in order, rather than themed sets? Join our overwhelming majority!!
  3. Peter Staddon
    Mar 16, 2000
    88
    Upgrade baby!!
    The new MC 12 is out and I need it!
    Peter
    PS how did the exams go?
  4. Vince Maskeeper
    Jan 18, 1999
    6,499
    Ah-ha! I was hoping it was a passage forward for you.
