Klipsch KSW-12 Subwoofer
Discussion in 'Archived Threads 2001-2004' started by Bill Balcziak, Oct 1, 2001.
  1. Bill Balcziak
    Bill Balcziak Supporting Actor
    Aug 4, 1999
    871
    This subwoofer is in like-new condition. It comes with the manual, original box and all packaging. The KSW-12 is an extremely powerful sub with all the bells and whistles.
    THE BLURB:
    The KSW-12 powered subwoofer uses a sturdy Klipsch bass woofer and Santoprene® rubber surround driven by a 440-watt, high-efficiency amplifier to fill your room with the ultra-force low frequency energy that breathes life into music and movies. The enhanced-performance, down-firing design and sonically tuned port enclosure contribute to the powerful, yet precisely accurate high output, delivering bass so low and strong that you feel it even if your human ears can’t hear it.
    THE SPECS:
    FREQUENCY RESPONSE: 26Hz-100Hz±3dB
    MAXIMUM ACOUSTIC OUTPUT: 113dB SPL 1/8 space, 1 meter
    ENCLOSURE TYPE: Bass reflex via rear-mounted port
    TYPE: 12" Bass reflex, tuned port enclsosure
    AMPLIFIER: Class A/B discrete MOSFET outputs
    AMPLIFIER POWER: 440 watts dynamic power
    AUTO POWER ON: 2 Second ON delay, 15 minute OFF delay
    LOW PASS CROSSOVER: Continuously variable from 40-120Hz, 24dB/octave slope above 120Hz
    INPUTS: 2) Line level/LFE RCA phono jacks and 2) High level speaker terminals
    OUTPUTS: 2) High level speaker terminals, high pass filtered at 100Hz, 6dB/octave slope
    PHASE: Switchable 0 or 180 degrees
    DRIVE COMPONENTS: Subwoofer system using one 12" (30.5cm) down-firing, fiber-composite cone woofer
    WOOFER: K-1071-K 12" (30.5cm) Fiber-composite cone
    DIMENSIONS (H x W x D): 17" (43.18cm) x 15" (38.1cm) x 15" (38.1cm)
    WEIGHT: 35 lbs. (15.9kg)
    $275 plus actual UPS shipping cost to your location. Please feel free to e-mail me at bbalcziak@hotmail.com for more information.
    [Edited last by Bill Balcziak on October 01, 2001 at 09:50 PM]
  2. Bill Balcziak
    Aug 4, 1999
    871
    ^^^bump^^^
  3. PaulWoll
    PaulWoll Auditioning
    Aug 19, 2001
    4
  4. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    Paul,
    From the posting guidelines for this forum:
  5. Bill Balcziak
    Aug 4, 1999
    871
    Yahoo "store" indeed. Go for it.
    [​IMG]
