Kenwood 6070 question (1 Viewer)
ericSchirm
I ran the searches without any luck. How can I get the center channel sound volume to stay in memory? By the "Sound" button I adjust my center channel up but each time I turn off the receiver I lose the value. Is there a way to set it into memory for each input?
Eric
John S
You mean you run a the basic calibration in setup and it does not save it at all????
Doug_H
You need to run it through the complete calibration. if you adjust it with the sound button you are only making a temporary adjustment.
acinstallation715
