Jolida 302B amp 4ohm OR 8 ohm speaker mine are 6 ohm?
Discussion in 'AV Receivers' started by Judy Y, Jun 8, 2003.
  1. Judy Y
    Judy Y Stunt Coordinator
    Feb 27, 2000
    Which hook up do I use? Sorry, I have read the OHM explanations but it just makes my head spin. The Jolida manual does not state which hook up to use 4 ohm or 8 ohm for different ohm speakers.
    I have Wharfedale pacific towers that are 6 ohm. I tried the bookshelf pacific speakers that I have with the amp at the shop and the amp didn't break a sweat. I believe my towers are more efficient........ anyway...... should I hook them up to the 8 ohm or 4 ohm spot?
    (I did write an email to Jolida- but don't really expect an anwer until tomorrow. I WANT TO HOOK THIS ALL UP BEFORE I HAVE TO GO BACK TO WORK tomorrow!)
    Any help would be appreciated!
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    The higher the output impedance of the power amp, the more the speaker takes on a frequency response curve that is related to its impedance curve. If that's how that's really supposed to be read, I'd imagine that you'd get a bit more of a bottom end, the speaker sound not you!, using the 8's.
