Shawn_T
- Sep 3, 2001
Hi All,
My rusty Sony 36" XBR250 WEGA TV can not output Progressive Scan, nor it has a 'manual' Vertical Squeeze feature, as a result, I am on a quest to get THE BEST video output device for my Console gaming needs. (Have all ‘Big Three’: Xbox, GameCube and PS2)
This Video Output Device of course is going to be either a new TV Set that has Progressive Scan feature or a plain old PC VGA Monitor. (my 22" ViewSonic PF815 Monitor which has BNC and VGA connectors in the back).
Of course there are some considerations going towards each path:
If I get a new TV set, then I have to shell out big bucks for it.
If I want to connect my console systems to my VGA Monitor, then I need a component-to-VGA transcoder.
I am in the market searching for THE BEST component-to-VGA transcoder, and so far I have found out that the Audio Authority 9A62 is a decent one.
Link Removed
rtner
At the same time I am searching for a good Progressive Scan TV Set (less than $1000 would be ideal though)
The cost is a bit of prohibiting factor (and I mean the $1000 range for a new TV Set compared to $300 or less for a component-to-VGA transcoder)
When I bought my Sony 36” XBR250 WEGA TV three years ago, I paid almost $2600 (plus $250 for its official (and only available) TV Stand))
I know the advantage of TV Set is the big screen, compared to a VGA PC Monitor, but at the same time, you get THE most tweakable set of features if you get a component-to-VGA transcoder (such as Audio Authority 9A62)
Your insights are greatly appreciated.
Link Removed
rtner
