Brett Creider
- Oct 7, 2003
Ok...so here's what I got...
I've got a Tempest powered by a 250watt PE remote control amp. It is in a 2x2x2' box and is just about the same size as the Low Q design Adire likes. It also has the same type of bracing and when I put salt on top of the box it is DEFINITELY stiff...
But one thing that is different is it is front firing and the front has double stacked MDF. 2 3/4" peices. At the moment they are glued in a little and screwed in near the outside...so no screws near the sub or anywhere else at all...
Right now it's too late to do anything but over there it would be like this:
Crank it to about 1/3 volume...be fine and dandy clean as a whistle, you're loving it. Turn it up a HAIR more and it sounds like it's bottoming out even though it doesn't seem it should be because the XMAX is crazy and the amp is 250, driver 750...
So is the problem the 2 peices of MDF not put together well enough and it's possibly clapping against each other...or is the sub actually bottoming out?
BTW: The box is glued, screwed, and caulked like no other...besides those front peices...
