Many members have emailed me about the fact that they are getting Internal Server Errors when they try to post or reply. The reason you are getting those is that is the way that I have it set up if you are trying to access the old forum. I don't want people posting something and having it show up on the old site to get lost as it is not getting posted to this site.
So if you are still getting and Internal Server Error on the board when you try to post/reply/edit that is because you are still hitting the old site.
The same issue applies with your cookie not sticking. The web address is working now so if you save a cookie with the domain name, ie. hometheaterforum.com your cookie will be lost when you log back on to the IP address or 207.173.159.237. When you can access the forum using hometheaterforum.com all the time then save a cookie on your computer by following the directions on the Preferences page and it should stick this time.
Again, sorry for all the hassles. This will all be resolved over next couple of days.
Parker
Parker
