IanB
- Aug 5, 2003
I was planning on insulating the wall in between my home theatre room and the laundry room. One side of the drywall(facing the home theatre room) is already done, what sort of insulation should I get/buy. Someone told me the foam sheets are better than the big insulation battens. I have drilled holes through the 2x4's and have run the wire through, should I actually run conduit and then put the wires inside or is that overkill.
Ian
Ian
