In pixels, what's the right dimensions of a DVD insert?
Discussion in 'Archived Threads 2001-2004' started by Mike Wegimont, Sep 25, 2001.
  1. Mike Wegimont
    Mike Wegimont Stunt Coordinator
    Apr 26, 1999
    130
    I want to make my own cover art for some cases. Can you tell me what size in pixels to make the image?
    Mike
  2. Bill Catherall
    Bill Catherall Screenwriter
    Aug 1, 1997
    1,560
    What's the resolution you seek? Is it 600dpi? 1200dpi? 1400dpi?
    Bill [​IMG]
    [​IMG]
  3. Mike Wegimont
    Apr 26, 1999
    130
    600 dpi should be fine, I think.
    Mike
  4. Andrew W
    Andrew W Supporting Actor
    Jun 19, 2001
    531
    don't confuse DPI with pixels/inch. Most color printers will print a photo quality picture at 300 pixels/inch.
    Remember it take one of each of a CYMK dot to defined each pixel. That means you get 4 or more ink dots per pixel plus some white space.
    Andrew in Austin
    Sony DVP-S530D DVD Player
    Sony STR-DA333ES A/V Receiver
    Sony KP-57XBR10W Rear Projection TV (16:9)
    Infintiy SM 120 (L & R)
    Infinity SM Video (center)
    Infinity SM 165 (surround)
    Infinity BU-120 (subwoofer)
  5. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    if you're using photoshop you can change the measure to inches, then just measure the case, and change it back to pixels to get the pixel size.. I'd do it but I'm at work with no cases [​IMG]
  6. Mike Wegimont
    Apr 26, 1999
    130
    Thanks, Philip_G, I didn't even think of that.
    Mike
