Clay D. Major
- Feb 16, 2004
Hey gang,
I just bought a house that included a very nice Home Theater set-up in the basement with a built-in big-screen and 5 in-wall Sonance speakers. I'm re-racking and re-wiring my own components and will be using the Onkyo TX-SR701 as my HT receiver. Problem is this: The 701 says not to use any speakers with an impedance rating of less than 6 ohms, as it may "harm the unit", but I have NO IDEA if the built-in Sonance speakers in my HT are rated below 6 ohms. There are no serial or model numbers on the back of the speakers that I can find, and they don't seem to want to come out of the walls for easy replacement, so I'm afraid to hook up my Onkyo until I know more about these speakers.
The HT was built around '96, I don't know if that helps. There are two wiring covers in each unit, one marked "5W2J" and "10W20J". Are those 10 and 200 watt references of some kind? What should I do?
Any help would be greatly appreciated. I'm a speaker moron. If these things would come out of the wall easily I'd just replace the suckers.
Thanks!!
Clay D. Major
Tekamah, Nebraska
Thanks!!
Clay D. Major
Tekamah, Nebraska
