George_W_K
Hello everybody,
I am currently powering my center channel, and three rear channels with my old Yamaha R-V1105. This is being used solely as an amp as I have a B&K Reference 50 pre/pro to do the other work. Unfortunately, my center channel has developed a low whiny noise that's very annoying. I tried hooking another speaker up in the same place and the same sound appears in that speaker so I know that it is the receiver. The problem is, there's one other channel I can use, but it emits the same whine. The other three channels are quiet.
I want to either fix whatever the noise is, or buy a replacement solution with at least as good as quality as the Yamaha assuming it weren't making the whiney sound. I'm basically looking for an interim solution until I can afford a nice amplifier later on down the line. I currently have a B&K Reference 200.1 powering my mains.
The reason I want a quick solution is because I am hosting a HT meet in September and I'd like to have a whine-free system.
I'm looking cheap, so it'll probably have to be used. $100 price range, but I'll go higher if something really good is available. The plan is to also have a pair of Axiom QS8s by my meet so I need to save money for those too.
As for fixing the problem, I think there may be interference with the Yamaha's display. When I change the dimming settings, the whine changes in pitch, but not volume. Does anyone know a way to disconnect the display without cutting anything? I haven't tried opening the receiver yet to see it there's something obvious.
Do you have any suggestions on which route to take, items to consider, how to repair the whine?
Thanks for any help or info,
George
George
