I need software for creating CD Inserts and covers
Discussion in 'Archived Threads 2001-2004' started by Philip Hamm, Jun 25, 2001.
  1. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Is there anything decent out there? I've been using the stuff that came with my CD-R machine a while back but it's too unstable to be usable, though when it works it does very well.
    I don't need anything fancy, just something that won't blow up all the time. Any recommendations? Paint Shop Pro 5 Templates?
    Philip Hamm
    AIM: PhilBiker
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    I use the Adaptec EX CD software at work and it does ok for what we need it. If you find a Paint Shop template though I'd love to get a copy
    http://www.attcanada.ca/~itisi
  3. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    I gave up on the few CD-specific applications I tried because of the lack of real features. I just use MS Publisher, but there's no reason why you couldn't use something similar. I've got a template set up for each type of stationary (I use two or three different brands of label and insert as well as my own cut-sheet A4 designs that you've already seen).
    Each template consists of two outlines - one which is the exact measurements of the label or insert and a second which is two or three mm larger. The second is for for flood-fills, to ensure that the colour covers the whole area of the label with no annoying white gaps.
    If you've got Publisher then I can supply you with the template files.
    [​IMG]
    "One does not simply walk into Mordor."
    Rob's Place
  4. Philip Hamm
    Jan 23, 1999
    6,873
    2
    Andrew, Thanks for the heads up! I hadn't noticed that EZ CD Creator has a little tool for this. I'll try it!
    Rob, Sounds neato. I do not have Publisher. Is it cheap? The only thing I have that is like a graphics program is Paint Shop Pro.
    Philip Hamm
    AIM: PhilBiker
  5. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    Cheap? Nah, it's Microsoft. I paid £100 for the full version of 98 a couple of years ago.
    Publisher is a DTP app so it's ideal for working with text and graphic layouts rather than doing 'arty' stuff.
    If what you've got can do line rectangles and circles, and can adjust them in tiny steps (Publisher I think will go down to 1/100th of a millimetre) then you should be OK. It will be a matter of trial and error to get the template to match your paper but once it's done you'll find it useful. Obviously you'll need to be able to insert graphic images and use any font on your system too.
    [​IMG]
    Rob's Place
  6. Scott Shanks
    Scott Shanks Second Unit
    Mar 10, 2001
    380
    Louisville, Ky
    Scott Shanks
    I use the HP CD-Labeller II. It's pretty good. Lots of options for what I use it for.
  7. Philip Hamm
    Jan 23, 1999
    6,873
    2
    Andrew Pratt, thanks a lot! I hadn't noticed that EZ CD Creator created inserts! That was all I needed, it works fine for my modest needs. Thanks for the info!
    Philip Hamm
    AIM: PhilBiker
