I got a FREE mountain bike ....
Discussion in 'Archived Threads 2001-2004' started by EddieN, Oct 14, 2001.
  1. EddieN
    EddieN Agent
    Sep 23, 2000
    35
    finally I have a bike to ride around. I live in Austin and always see people on bikes and it seems like a great town to ride around in. It was fate. I was leaving the apartment and see a bike leaning up against the dumpster with signage on it that said FREE bike. It's really dirty and looks like it hasn't been used in ages. I lugged it up the stairs, it's pretty heavy, but it's a free bike. It's a Trek Antelope 800, it has Shimano Atlus C20 gear changers and what not, can't see what kinda tires are on it because it's so damn dirty. I like new projects and getting this baby all clean and greased up will be fun.
    Should I just use water and soap to clean the frame and gears or is there something better ? Is standard grease and oil used for the chain and gears and ball bearings ?
    - Eddie
  2. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    You dont needa clean out the bearings or anything...
    You could clean the deralleur and the rear gears though... You could wipe it down with a unwanted rag, or spray some degreaser on it, let it soak, then wipe it off... try not to use water around any bearings, they'll get in there, and get rusty or the dirt will stick easier and you'll have a whole pile of crap in there...
    Also, buy a chain remover... Get that, remove the chain, then spray it with degreaser, let it soak, wipe dry with rag, then place back on the bike, lube it up with some chain lube (I recommend White Lightning)... The type of lube varies in climate... if you're riding in dry dusty desert, get a dry lube (whitelightning is dry), if its wet soggy mud, get a wet lube... [​IMG]
    The So Family Home Theater!
    http://www.multimania.com/sonick182/ht/index.html
    You're all entitled to your opinion, but you're all wrong!!! - Paul Dalmine
    ICQ: 8593599
  3. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    Hey, a free Trek sounds great to me.
    Brent L
    OK guys ..... The tour of the Paradigm
    plant is now being planned. GO TO THE HOME THEaTER
    MEETS PAGE and register.
  4. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
    White Lightning is a wax based lube and it works for some people in some conditions and not others in others.. WL is weird in that way, you get people who swear by the stuff and others who hate it. Personally, I would stick to good ole oil based lube for abit to see how that works for you. I've used Finish Line and Krytech stuff for years but then again I get alot of free samples and stuff from the rides/races that I do. So if you get a decent citrus degreaser and some old rags, you can degrease the chain and relube.
    As far as cleaning, warm water and soap is good. Like Nick says, keep away from the rotating parts (hubs, bottom bracket (the crankarms that you pedal go through the BB), headset (where the fork goes through the headtube), etc.
    Depending on how bike-inclined you are, it might be worth it to take it to a bike shop for the once over. But at a minimum, you should thoroughly inspect the brakes, the brake pads, the spokes on the wheels (should be tight) and you can inpect the frame carefully for any cracks before you ride it. being a free bike, perhaps your $70 bike tuneup might be worth it. I think I remember the Trek Antelope bike, but for some reason, I'm thinking hybrid, but then that's just my memory. I'll take a look. It's also probably a good idea at a minimum to take a 4/5mm hex wrench and tighten as many things you can find on the bike that fits, the brakes, the stem, the headset, etc...
    If you find anything specific, just reply and the HTF bike nuts will try to help you out!
    Keep riding!
    Jay
    HUGBEES! My Equipment List
    Rider in the 2001 Alaska AIDS Vaccine Ride
    Wanna help?
  5. EddieN
    EddieN Agent
    Sep 23, 2000
    35
    Thanks guys, really appreciate the suggestions. I just started a new job today at MCI Worldcom so my Trek hast to wait until Friday to get cleaned. I always feel so lazy after work. I'm also gonna call up some bike shops in the area and see what they charge for a "tune up".
    - Eddie
  6. Paul Wu
    Paul Wu Stunt Coordinator
    Oct 28, 1999
    96
    If the bikes been around the block so to speak, you may be in for a bit of work.
    How freely does the wheels spin? Just hold up the front and give the front wheel a spin. Look for 2 things, 1-Does the wheel spin completely around a few times? Or does it have trouble making it around even once? 2-Keep an eye on the rim, the shiny part, not the tire, and the brake pad. Do you see the rim move in and out, does it touch the brake pad? If it wobbles, the wheel is out of true, and will need a bit of adjustment to get it straight. If it bumps the pad, either the wheel is really out of shape, or the brakes just need some adjustment. Do this with the rear wheel as well.
    Next how does the chain look? Is it bone dry? or is there some black gunk on it and grimy? You can buy a chain cleaner that clamps onto the chain without taking the chain off, but this tool used to be like $30, or you can get a chaintool, which should only run about $5. One thing, I may be out of date here, but when you pop off the chain, you need a special replacement pin, you can't use the old pin. This was with the old Shimano Indexing and hyperglide stuff, so I don't know if it would be appicable. But it sounds like an older bike. For cleaning the chain, you can also use some WD40. Make sure you do buy some bike oil from a bike store. I used to use Phil's, don't know if it's still popular or not.
    Actually there's a bunch more that can be done, but I think I'll stop here. It might be well worth it to take it to a shop for them to look at it.
    A Typical tune up used to be:
    Check and adjust:
    Headset
    Hubs
    Bottom Bracket
    Brakes, cables and pads
    Gears, front and rear deralliers
    True the front and rear wheels
    Remove and clean chain, rear gears, and front chainwheels.
    We used to charge about $35, but this was like 10 years ago.
    Please note the "Check and adjust," all this means is an inspection and to make sure everything rolls smoothly. However, if you've got an old bike, chances are you may need to replace some bearings, or at the least regrease your hubs, headset and bottom bracket. This would involve quite a bit more work. So you might get a call from the shop saying "we need you to authorize some more work."
    Another option is the "Compete Overhaul" which would include the following:
    Replace bearings and grease:
    Hubs, headset, and bottom bracket;
    Replace brake and derallier cables
    Replace brake pads
    True up front and rear wheels
    This would normally cost $100, but would ensure that you've got a well running bike.
    However, note the "replace bearngs," unfortunately the bearings are only half the story. The bearings run on the metal surface, and there's a chance that there may be pits or little indents along the surface. So you may still get a call saying you may want to replace the headset or bottom bracket. Again more money. Oh boy, now that free bike is costing you major bucks. [​IMG] I hope I'm not bringing you down.
    But getting back to the free part, since it was free, I wouldn't worry about pitted surfaces, or even bother regreesing the bearings. I mean unless you are going to ride alot.
    Uh, I think I've rambled enough for now.
    Paul Wu
    "There are three kinds of people in this world; those that can count and those that can't."
  7. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    32
    Pittsfield, MA
    Jay
