i can't get my cookie to stick (1 Viewer)
Ted Lee
hi all -
i hope this is the right place to post this. i absolutely cannot get my cookie to stick. i've tried all the suggestions posted, including removin the cookie, setting the preferences, then posting a new thread to make it stick.
any other ideas?
tia
You step in the stream,
But the water has moved on.
This page is not here.
Rob Gillespie
Ted, first of all make sure in your internet settings, or any kind of filtering software that you're not blocking cookies to this site.
This is how I get it to work (in strict order):
[*]Go to the Preferences page[*]Delete the cgi-bin cookies from your WindowsCookies folder[*]Select and set the preferences you want.[*]Go to to the forum index page and click on the icon near the top to log in[*]Go to the testing area and post a note
That should do it.
Ted Lee
thanks rob! it looks like it worked fine! thanks for the quick response!
acinstallation111
