Wade
- Jun 30, 1997
I had practically every room in our house pre-wired for ceiling fans so the boxes are already in to attach the fans to. I installed a Lowes Harbor Breeze fan in our daughters room without a problem, but the Hunter fan has a different mounting scheme. You're suppose to install these four rubber isolators to the ceiling plate and then mount the plate to the ceiling. Here's where I had the problem. The manual tells you to not over tighten the two mounting screws but when I was tightening down the screws a couple of the rubber isolators cracked the drywall. Well that was obviously too tight. I rotated the plate and didn't tighten the screws as much.
My question is are you suppose to compress the rubber isolators a little then leave it at that? I was worried the screws would back out eventually if not fully tightened?
Call me an idiot but I just want to ask before I install the other five Hunter fans I have.
Wade
Wade
