Sean Frost
- Apr 29, 2003
David, that was a great review. I also heard there was an audio glitch. Did you notice anything like that besides the pause where it branches?
The layer-like break (anyone know if it *is* a layer break or not?) right after the morning report scene where the two versions "branch back together" looks/feels like a normal layer break...which means that it would cause the audio to mute for a fraction of a second or two (it did on my panny rp91). I think that's some folks may have reported as an "audio glitch"...they're really just noticing the auido pause momentarily during the "layer break". Depending on your player, it's no different that the normal audio pause/glitch you experience during a normal layer break on any other DVD.
My assumption is that maybe the two versions start on layer one each with their own video stream (not multi-angle, but rather two separate branches) and then they hit the layer break and share the same video stream for the rest of the movie on layer two. This places the layer break oddly close the to beginning of the movie...my suspician is that most of the extra SE stuff on disc one is actually contained on layer one and that layer two is dedicated to the bulk of the film. Again, this is all an assumption of mine based on the very real "layer change" pause I'm seeing right after the morning report. I think BB&TB also used a layer-change to mark the beginning/end of a branching stream.
-dave
"6 out of 5"... is it me or is that destined to be a classic line?"Yes, but, this one goes to 11."
-Lyle J.P.
So I take it Zazu's menu navigation tips are not voiced by Rowan Atkinson?You take it correctly! Either that or his voice changed a lot over the last decade...
anyone know if it *is* a layer break or not?It is, yes, and your assumption is spot on. For both cuts of the film, everything up to and including that scene is on Layer 1 (or Layer 0 as my Sony deems it) of the DVD. Then, again for both cuts, it switches to the next layer thereafter.
This layout would also indicate then that the second layer contains two alternate titles for the different end credits both cuts of the film carry. Whilst both on the first layer, the alternate opening titles are set to title 35 for the special edition, and 36 for the theatrical. The same title designations remain for the film's end credits.
Dan
